Good morning?
Happy Christmas. Are everyone having a relaxing Christmas?
I am using FC9.
I want to use the latest version of the compiler or download tool. However, if you change the directory, it will not compile or download. The latest version of XC8 is 2.31. The file included in FC9 is 1.45. Modern MCUs do not compile. Please suggest a solution. Please also XC16.
Thank you.
Happy christmas
compiler option
- Has thanked: 5 times
- Been thanked: 7 times
- Has thanked: 169 times
- Been thanked: 285 times
Re: compiler option
You will probably need an appropriate batch file to allow Flowcode to work with an alternative toolchain. If you download and install the toolchain from the flowcode.co.uk site, you will find the batch file off the root of its installation location and it might be enough to copy this folder to your alternative toolchain location and then point Flowcode at this alternative toolchain.
We're happy for you to use a different toolchain. However, we cannot guarantee that Flowcode will compile correctly on an alternative toolchain and we might not be able to support you if you run into problems.
- Has thanked: 515 times
- Been thanked: 474 times
Re: compiler option
I would be able to test all is working until tomorrow with Flowcode 9 & the latest XC8 compiler only.
If it works and you want help in setting it all up, then I can help you with that.
Re: compiler option
Just tested a v9 flowchart compiled with XC8 v2.31 using 12F1572 and compiles OK for me:
C:\Flowcode Batch Files\XC8 v2.31.bat 12F1572 "C:\Users\MartinW\Downloads\" "Interrupt_Falling_Edge"
C:\Users\MartinW\Downloads>"C:\Program Files\Microchip\xc8\v2.31\bin\xc8-cc.exe" -mcpu=12F1572 "Interrupt_Falling_Edge.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
Memory Summary:
Program space used C0h ( 192) of 800h words ( 9.4%)
Data space used 19h ( 25) of 100h bytes ( 9.8%)
EEPROM space None available
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Compilation successful!
C:\Program Files (x86)\Flowcode v9\data\tools\DoNothing\DoNothing.exe
FINISHED
