Hi guys,
I've been using Flowcode for a very long time, always with PIC16/18/32. It has always been very straightforward to make an LED blink every second from within an interrupt for testing...
However I'm trying ESP32 and need some help with interrupts as can't get this to work at all
I've enabled Interrupt 0 and a simple counter code inside, but the interrupt doesn't seem to be behaving as expected. How is the interrupt period set/calculated in ESP32 chip?
Thanks for your help!
R
ESP32 INTERRUPT PROBLEM
- Has thanked: 26 times
- Been thanked: 11 times
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Re: ESP32 INTERRUPT PROBLEM
Hi.
I have done the setup for 200 mSec interupt in Timer0 ,tested on my WROOM board working fine
it only flash the onbaord led at 200 msec intervals as I tested only the interrupt
Thanks for this,
OK that explains it! The period cannot be set to 1000, it's strange as that's the setting there on the menu when on milliseconds... And the integer has to be smaller than 256
So all fine now, that makes sense. It's not as flexible as the PICs, but very simple to use!
Spasiba!
R
Spasiba!
R
- p.erasmus
ne cha sto
You can also set the properties to seconds and enter 1 in the period then it also works for second counts
