Q1. Is there a way to increase the font size (make it larger) in the Target Device window?
When using Flowcode V10 with an 85" Monitor (Samsung TV: 3840 x 2160 at 150%, Windows 10)
the "Target device" window font is quite small (hard to read at a distance).
NOTE: Most other windows can be scaled up or follow the General Configuration Font Settings.
Q2. Also, (this is not a big thing however) the "STM32F746NG_gLCD_Demo.fcfx" appears to not
work correctly -- for example:
- when "Call Component Macro GLCD_STM32F746NG::DrawCircle(X,Y,2,0,1) values are
changed and the code is run, the changes don't seem to follow the new values in the
simulation.
- Haven't fooled with it much, but it's the same in Flowcode V8 Full version and V10 Free version.
Flowcode V10 - Target Device Window - Font size increase?
- Been thanked: 2 times
- Has thanked: 173 times
- Been thanked: 292 times
Re: Flowcode V10 - Target Device Window - Font size increase?
Q1: you can scroll the mouse wheel to change the size of the whole target view.
Works great! (I'll upgrade to V10 Pro and look into Q2. in more detail)
Thanks Steve
Thanks Steve
Quick Note - Upgraded to Pro - WELL WORTH IT IMHO - stepping through the Macro's alone is very helpful...
Thanks again!
Thanks again!
I had no idea you could do this. I have been squinting with my old eyes at 1mm text on my 4k 27" monitor...Steve-Matrix wrote: ↑Fri Jun 30, 2023 9:03 amQ1: you can scroll the mouse wheel to change the size of the whole target view.
Chad
