I guess it still needs a firmware for the ESP32 to use it as a slave.
Is this already available? Or is one already planned?
https://www.flowcode.co.uk/wiki/index.p ... ed_Devices
App Developer (SCADA Slave) API devices for ESP32
- Has thanked: 152 times
- Been thanked: 179 times
- Has thanked: 454 times
- Been thanked: 614 times
Re: App Developer (SCADA Slave) API devices for ESP32
Hi Stefan,
The firmware is available here.
https://www.flowcode.co.uk/wiki/index.p ... e_Devices)
Let us know if you have any problems.
Aha Martin beat me to it
Hi Martin, Hi Ben
Many thanks.
I found the ZIP Folder with two program for the ESP32
ESP32_API_Comp.fcfx
ESP32_API_Firmware.fcfx
So I loaded the ESP32_API_Firmware.fcfx to my esp32 board an I can connect it to my network already.
For the App Developer I found some template .
But which of these is for the ESP32?
Many thanks.
ESP32_API_Comp.fcfx
Hi Martin, Hi Ben
I used the ATOM Matrix with a mpu6886. This mpu6886 is working with bluetooth nice on Port A25 and A21 with Flowcode.
https://www.digikey.co.uk/en/products/d ... B/12088569
I made the config for the pin in the ESP32_API_Firmware_post in the same way.
For the App I wrote a small program.
Unfortunately the init from the mpu6886 is not working.
I noticed that the wifi connection is fine, RX and TX blink when the Atom module is running and rx tx stop blinking when I turn off the Atom module
I suspect I'm doing something wrong with the I2C
- App_for_API_ESP32.fcsx
- (23.4 KiB) Downloaded 90 times
- ESP32_API_Firmware_post.fcfx
- (167.61 KiB) Downloaded 101 times
