Print Formatted Number
Has thanked: 536 times
Been thanked: 485 times
Could PrintFormattedNumber be added to all displays and not just LCD?
Then gLCD can display Long and Ulong numbers, rather than restricting to signed Ints e.t.c.
Has thanked: 455 times
Been thanked: 621 times
Re: Print Formatted Number
Good suggestion thanks. I'll have a look shouldn't be too tricky to do :D
While I'm at it what about a print float function with number of floating points param?
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
BenR wrote:
Wed Jan 20, 2021 10:00 am
This is always useful never mind the application LCD,gLCD even in Serial coms :D
Thank you.
That is a great idea!
p.erasmus wrote:
Wed Jan 20, 2021 10:04 am
I fully agree with that.
Has thanked: 175 times
Been thanked: 299 times
I realise it's an extra step, but you can always convert the float to a string in a calculation and use the string if the component can't handle the float.
p.erasmus
Post by p.erasmus »
:D
Thats true too Steve :D
