App Developer: USB Webcam Component
Has thanked: 151 times
Been thanked: 171 times
Flowcode v10 App Developer: USB Webcam Component
How about a component for the App Developer for a webcam connected with a USB cable.
The first thing you should see is an image in a 2D panel.
The easiest would be these cheap cameras with full HD resolution.
Later you should be able to read one (or every) line of the camera with Flowcode.
This way it would be possible to recognise simple objects with flowcode or to use a cheap USB camera as a linear camera.
A real linear camera is much faster and much better but unfortunately expensive.
Different very cheap, easy to connect USB cameras
A professional linear camera over network (GIGE) with up to 80000 lines per second
Has thanked: 447 times
Been thanked: 607 times
Re: App Developer: USB Webcam Component
Hi Stefan,
We have a canvas object in Flowcode that we can draw bitmap data to, if we can pull a bitmap from the camera source and repeat then should be easy enough.
I'll have a chat with Steve and see what he thinks.
I looked at the canvas and that's how it should be.
I only film or photograph two or three white dots with the cameras and want to calculate the distance.
For that I would have to have access to the data array.
I guess I can then also display a cross in the image via an array.
And another little info, the external USB cameras have become even much cheaper.
Of course, other applications can also be made with the cameras like bar-code or QR Code.
