The uart or com component can Send/ Receive Byte Array or Int Array
This sending and receiving arrays is working perfect and it's so simple to use.
And it saves a lot of trouble .
One more question, why is the Byte Array unlimted in the size and the Int Array limited to a Byte size (255) ?
Send/ Receive Byte Array vs Int Array
- Has thanked: 149 times
- Been thanked: 171 times
- Has thanked: 439 times
- Been thanked: 603 times
Re: Send/ Receive Byte Array vs Int Array
Hi Stefan,
No real reason, I'll see if we can move that to an UINT too without causing any knock on problems.One more question, why is the Byte Array unlimted in the size and the Int Array limited to a Byte size (255) ?
