Just noticed that on the above chip I have UART options for Software and Channels 1-3. However irrespective of what I select, the pins cannot be changed from $PORT.B2 and B1 for Tx/Rx (even if Alt Pin is enabled).
Using latest FC with updated DB.
ESP32-Lolin-Lite UART
- Has thanked: 289 times
- Been thanked: 424 times
- Has thanked: 449 times
- Been thanked: 609 times
Re: ESP32-Lolin-Lite UART
We've locked Uart channel 1 to port pins a1 and a3 as they are used for both reprogramming and for debug. Do you need three uarts or can you use one of the other hardware channels.
It doesn't matter what channel I select, the actual pins cannot be changed. Channels 1-3 and software all use $PORT.B2 / 3
- Has thanked: 522 times
- Been thanked: 477 times
Hi.
Thank you for reporting this bug.
Can you try with the attached component, please?
For anyone who wants to try but does not know component locations.
save the attached component in the above location
If Flowcode is already open, then you will need to reload your project for the new components to work.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
- RS232.fcpx
- (90.63 KiB) Downloaded 40 times
Travelling, so will try later in week but I'm sure it will be good
