ATMEGA328P ILI9488 hardware SPI not work
barmaleyka
Has thanked: 1 time
Post by barmaleyka »
Hello. With the ATMEGA328P microcontroller, the ILI9488 SPI display does not work hardware SPI, the MK just hangs. The software SPI works, but very slowly.
Has thanked: 536 times
Been thanked: 485 times
Re: ATMEGA328P ILI9488 hardware SPI not work
Can you post your fcfx and .c files please.
Have you run Library updates to make sure you are sung the latest components?
barmaleyka
Has thanked: 1 time
Flowcode1.fcfx
(11.87 KiB) Downloaded 772 times
Flowcode1.c
(110.11 KiB) Downloaded 771 times
Can you try the attached please.
If it works, it's because the O/P is the SS on SPI hardware.
If unconnected or low, it puts the SPI in slave mode and causes it to lock up.
SS must be either connected to a pull up resistor or set output to high.
Flowcode1 barmaleyka.fcfx
(12.08 KiB) Downloaded 712 times
barmaleyka
Has thanked: 1 time
Hello. Yes, the MK is working, but the display does not work, the screen is white.
Sorry, I have just spotted you have PrintNumber, then ClearDispaly straight after.
That means you won't see any chars printed.
Try both of the attached projects
Flowcode1 barmaleyka v1.fcfx
(12.52 KiB) Downloaded 692 times
Flowcode1 barmaleyka v2.fcfx
(13.47 KiB) Downloaded 686 times
barmaleyka
Has thanked: 1 time
Unfortunately both options didn't work
I have just ordered a display.
Hopefully, I will then be able to resolve this for you.
Chadb
Has thanked: 24 times
Post by Chadb »
Hey, I ordered a 3.5" display that claims to be an ILI9488. Reading the comments on Amazon it is actually a ILI9481. I haven't gotten mine yet but might explain why there are some issues. I am going to try to get one of these working with the ESP32. There are a lot of these on Amazon now, so it would seem that this is going to be an issue for driver support.
https://www.amazon.com/dp/B0BWJHK4M6?re ... tails&th=1
Chad
jgu1
Has thanked: 517 times
Been thanked: 135 times
Post by jgu1 »
Hi Chad!
I can recommend to use the Ili9488 display with ESP32. Ben have managed to speed these display up and they are really fast. You can also use ST7796 4" and this is the fastest. Have a look here: viewtopic.php?f=3&t=1851
I have some examble with these display as I use as standard setup when I made a new project included touch fuction, I can share with you if you want?
Look forvard to see if Martin is able to speed up with AVR, I know form earlyer these are little slow ;)
Br jorgen
