The APA102 demo project (and others I have saved from it) do not save the port pins. I set the clock pin to G2 and MOSI to G25 and all works fine. When I re open the project they have reverted back to G10 & G11.
Bob
Project does not save port pins
- Has thanked: 25 times
- Been thanked: 30 times
- Has thanked: 536 times
- Been thanked: 485 times
Re: Project does not save port pins
Hi Bob.
Hopefully, this will sort your issue out.
Place the attached component.
If you run any component updates, then the component you added will be overwritten, so it will stop working again.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
- LED_APA102C.fcpx
- (13.28 KiB) Downloaded 53 times
