EEPROM FCD error in compiler
hiromiyureei
Been thanked: 1 time
Flowcode v9 EEPROM FCD error in compiler
Post by hiromiyureei »
Good morning, I'm using 32mx575f512h, when I use the eeprom component and insert
read or write the compiler gives me the following error message,
Where am I doing wrong?
hiromiyureei
Re: EEPROM FCD error in compiler
Solved, I checked the datasheet carefully and this microcontroller does not have the eeprom, but the flash memory, it would be nice if flocode would warn and not allow the insertion of the object.
