Trying out ESP32S compilation to chip but it fails
1. Have included the compiler status file
2. Also screen showing the default storage for the compiler etc
3 Note i can see the new com port is there okay so it can see the chip okay
Appears something may be mixed up in the directories as appears cannot find the the file ?
Have not included the program as for test purposes merely " begin" and "end "
Can you advise
David
ESP32 not compling to chip
- Been thanked: 18 times
Re: ESP32 not compling to chip
Please find second attachment again as didn't appear to go with first report for some reason
David
David
Attachment 2 but zipped this time to reduce size
DAVID
DAVID
- FILE2.zip
- (280.93 KiB) Downloaded 192 times
- Has thanked: 73 times
- Been thanked: 218 times
Looks like the ESP toolchain is not fully installed.
These instructions should help ...
https://www.flowcode.co.uk/wiki/images/ ... ctions.pdf
- Has thanked: 170 times
- Been thanked: 287 times
For future reference, the messages from compilation are automatically saved to a text file in the same folder as the Flowcode project (in your case, it would be "C:\Users\david main\Documents\Flowcode1.msg.txt"). Attaching that would probably be easier than creating a screen grab.
hI
Followed installation instructions again but appear to be getting same results getting same results
Note file is now called TESTPROG1
DAVID
DAVID
- Flowcode1.msg.txt
- (2.3 KiB) Downloaded 189 times
Do you have an "ESP-IDF Command Prompt (cmd.exe)" on your desktop?
If so, can you run it.
Then type idf.py and press enter.
Does the screen then have a list of commands?
Ah, also just spotted something else... "C:\Users\david main\Documents\"
"david main" could be the problem here.
Could you try creating the Flowcode project in a directory path that does not contain spaces.
HI
Ran the idf.py
ran okay and gave message
Done! you acan now compile ESP-IDE projects
GOto Project directory and run
idf.y build
But i am Not sure where what Project directory is ???
I also changed then changed the storing of the project to C:flowcode9 (ie no spaces)
have enclosed compiler msg file of latest run
David
Ran the idf.py
idf.y build
David
- ESP32_TEST5.msg.txt
- (1.96 KiB) Downloaded 181 times
OK, thanks, if you can now try the following in the command prompt box ...
Then see if it does a build, which takes several minutes.
cd C:\FLOWCODE9\ESP32_TEST5
idf.py build
