PIC24FJ128GB204 IOC simulation and pin config
With interrupts enabled and breakpoints inserted, Flowcode closes after a few seconds at a breakpoint. The pin configurator for the processor only allows "Trigger on both edges".
- Has thanked: 440 times
- Been thanked: 603 times
Re: PIC24FJ128GB204 IOC simulation and pin config
Please can you post the project that shows this behaviour so we can investigate. There is a known bug in the application regarding simulated interrupt pins which is due to be fixed shortly, likely this week.
It is now 30 December 2022 and the bug is still not fixed. When will it be addressed?
- Has thanked: 167 times
- Been thanked: 277 times
The bug Ben was referring to was fixed at the beginning of November. Please see this post for the details.
I am not sure if this relates to your problem. As Ben said, please post an example project showing this behaviour and we'll be happy to look into it.
