SHT21 macro error
- Has thanked: 3 times
- Been thanked: 4 times
SHT21 macro error
SHT21 macro error. During the simulation process, the obtained data is basically unchanged. Always show a fixed value.
- Has thanked: 169 times
- Been thanked: 285 times
Re: SHT21 macro error
I'm not familiar with that component, but when I run a simulation the values displayed on the LCD are not fixed and do change. However, the values are not the same as those on the SHT21 component. The Humidity changes between -6.00 and -5.88, and the Temperature changes between -46.8 and -46.5.
- Has thanked: 514 times
- Been thanked: 474 times
Thank you for the spot.
It is a bug and I have now fixed it, so you will get the full range that the component shows.
The fixed component will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
Replace the existing files with the attached files.
If you run any component updates, then the components you added will be overwritten.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
- EBM016_Humidity.fcpx
- (4.9 KiB) Downloaded 38 times
- Humidity_SHT21.fcpx
- (4.89 KiB) Downloaded 40 times
I can confirm the updated component has been pushed onto the update system.
If you run a component update The component I posted will be replaced with the latest version.
- Has thanked: 509 times
- Been thanked: 132 times
Hi Martin!
Sorry for brake in The value change now in simulation after update, but if I try to move the component in the 2D panel, it is not possible and if I try to increase them it not possible or make a strange size?
Jorgen
Jorgen
hello Jorgen.
I just added a new 2D panel and it moved OK.
It just ended up in the top left corner. After dragging and resizing all was good.
Try this.
Drag the component you wish to move to the bottom right of the center cross of the legacy panel and then use the move command.
If the component does move out of view just set Y and X locations to 0, 0 from the properties.
Try this.
