The hardware does not run after downloading to the chip using port programming
- Has thanked: 3 times
- Been thanked: 4 times
I use esp32_ WROOM_ 32 controls 4 LEDs, with control pins in the flowchart. After downloading to the chip, the hardware runs normally. However, if the port is controlled in the flowchart, the hardware does not run and the LED does not light up after downloading to the chip. Please help me take a look! Thank you!
- A06.png (138.88 KiB) Viewed 16682 times
- LED_PORT.fcfx
- (10.45 KiB) Downloaded 658 times
- LED_Pin.fcfx
- (10.45 KiB) Downloaded 677 times
