I am writing a project which works on the simulation when "debugging" but when compiling to target it gives the error "Syntax error 988" unable to compile to C.
Please advise what this particular error means, thank you.
Syntax Error 988 - simulation working but cannot compile to C or compile to target - Arduino
- Has thanked: 544 times
- Been thanked: 499 times
Re: Syntax Error 988 - simulation working but cannot compile to C or compile to target - Arduino
Can you post your project file with extension .fcfx
Also post your .msg.txt file.
Then it can be investigated
