Can you connect the GPS module directly to a PC and capture the dump the module sends out. That will really help to identify the issue.
With anything to do with UART a USB-TTL gadget such as below is your best friend.
https://www.amazon.co.uk/CP2102-Serial- ... tdGY&psc=1
GPS not send LAT_LONG
- Has thanked: 285 times
- Been thanked: 412 times
- Has thanked: 20 times
- Been thanked: 6 times
Re: GPS not send LAT_LONG
Yes, of course, no problem about that, I'm going to check outside the house, maybe the signal will improve
- Has thanked: 507 times
- Been thanked: 132 times
Hi again both/all!
Try to look at this, very simple way to figure out if you have connection with the gps module or satelite
Look at the hole video
https://www.youtube.com/watch?v=hbRpr1HbDf8&t=280s
Jorgen
Jorgen
I am going to do tests with all the information obtained from you, I greatly appreciate the help you have given me, I will keep you informed; Right now I can't move from here, I'm doing what I can, with the things that I have.
Sadly I still cannot receive LAT and LONG; but I will keep trying until it is achieved and I find the fault.
Excellent video, perhaps a better antenna or an open place is required
Enrique
Best Regards !!!
Enrique
Best Regards !!!
- test1.jpg (57.72 KiB) Viewed 451 times
WORKING GPS !!!!!
I did tests when I was in home, another common detail is that approximately 8 months ago, I worked in a place that was a large and open construction warehouse (there was a good signal there) and I didnt have any problems. Coincidentally I started doing tests a few weeks ago, but in the new workplace (with 2 roofs) one made of concrete and the other of metal structure, the place is not very large; I didn't think that the GPS reception can be affect by the structure, but in fact that affect the signal ; After days trying to achieve the sending of coordinates without success and about to leave the project, the video sent by Jorgen commented the importace of open places for the signal, as the recommendations of the rest of the Flowcode team Chipfryer27, LeighM and Martin who were helping me. Im very thankful with everyone.
Fortunaly it was a logic solution at the problem, just taked some time.
Enrique
Thanks and my Best Regards !!!
Enrique
Hi Enrique!
Glad to hear, also Strange it not work by you,but at me, maybe I am closer to the Moon than you good ideas from Leigh, Martin and Chipfreyer
Good luck
Jorgen
Good luck
Jorgen
It's possible. . .here we are surrounded by mountains, but we don't live above!!!
we are below them.
Thank you Jorgen !! and Good luck to.
Enrique
we are below them.
Enrique
