Is it a bug or a feature?
When using the RTC from the ESP32 component: shouldn't this update the date accordingly to the chosen offset in the UTC setting?
Now the time is updated to the offset in the component properties (or like in my case: the RTC_ESP32_NTP: SetUTCOffset component macro), but the date doesn't update. This changes only at the moment the UTC date changes..
ESP32 RTC: date when using UTC offset
- Has thanked: 75 times
- Been thanked: 50 times
- Has thanked: 442 times
- Been thanked: 604 times
Re: ESP32 RTC: date when using UTC offset
I've had a look and we seem to be doing things right. What value are you using for yout UTCOffset?
