Just trying out new Flowcode 9 a couple of small initial issues
1 I note that the ghost mode for arduino uno still refers to DO & D1 as the control pins
for flowcode 8 you sent me a new temporary fcd which was fine but i hoped this would have been fixed permanently in flowcode 9
2 The icon for state machine does not appear to be enabled
Also is there an example or info how to use the state machine function
3 Any idea when will the pricing info be available
Davidj
Arduino ghost mode
- Been thanked: 18 times
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Re: Arduino ghost mode
It seems the pricing is available if you go to FC web page and press the buy button and select new or upgrade user the pricing will show up
- Has thanked: 168 times
- Been thanked: 285 times
I've told my colleagues about this and it should be available via a library update at some point in the near future.DAVIDJOINER wrote: ↑Fri Dec 04, 2020 9:58 am1 I note that the ghost mode for arduino uno still refers to DO & D1 as the control pins
Could you elaborate on how it is disabled? And info on state diagrams is here: https://www.flowcode.co.uk/wiki/index.p ... e_diagramsDAVIDJOINER wrote: ↑Fri Dec 04, 2020 9:58 am2 The icon for state machine does not appear to be enabled
HI
1 Re the Ghosts thats fine look forward to the update in due course
Presume i can use the temporary FCD you previously sent me for Flowcode 8 and paste it into the Flowcode 9 folder in the meantime ?
2 I have followed the link you sent regards the state machine and now working fine
many thanks for prompt replies
David
David
- Has thanked: 446 times
- Been thanked: 606 times
Hi David,
I've now added the new FCD into v9 for you. It should be available via the update system.
