I'm using a ST 7920 GLCD in a project, but it doesn't works in parallel mode ( and use too many pins), I'ts possible to create a SPI version to this component?
SPI version of the ST 7920 GLCD
- Been thanked: 1 time
- Has thanked: 455 times
- Been thanked: 621 times
Re: SPI version of the ST 7920 GLCD
Yes looks possible, on your display do you have access to the pin (PSB) that sets if the display has a parallel or serial interface? This is often the limiting factor.
Great, I've made the change to the component to allow it to be configured as an SPI mode. I've not tested it so let us know how you get on.
The latest version is now available via the Help -> Library updates.
Thank's Ben, it will very useful. I'll test and report the results.
Hi BenR,
Unfortunately, the SPI mode doesn't work, squares appear instead of letters.
Ok sounds like the write is maybe working but the read back isn't. I'll have another look at the code.
