GLCD (ST7920)
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Re: GLCD (ST7920)
If you have issue or concerns at least take the time to explain your issue with the component ,if you do not care to take time to explain your problem why should we the users take the effort and time to help ,if you yourself consider it so less important that you do not spend time to give a clear description of your problem,
