App Developer connect to ESP32 S3 with USB
Has thanked: 149 times
Been thanked: 171 times
Hi to All
One more question. With purchased hardware with an ESP32-S3, I have to press the reset button for 5 seconds to flash the firmware.
Then press the reset button again.
The programme runs.
Now I want a connection with the USB C connector to the computer.
A serial device com15 and also an USB jtag/serial debug unit appear in the device manager of the computer.
but I can't make a connection with the App Developper with Com 15
and I don't have a pin for the interface in the firmware either.
Is this connection possible with USB component ?
Has thanked: 168 times
Been thanked: 279 times
Re: App Developer connect to ESP32 S3 with USB
I think you will need to use the Serial Port component and not the USB component.
Hi Steve
I suspect it's not that simple.
The USB pins go directly to the ESP32 C3. So I can't use an Rx/TX pin. Many ESP32 boards have a USB driver that goes from the USB connector to the UART pin.
What about BLE Uart? Is BLE already possible to test?
Sorry, I'm not familiar with that device. You should be able to communicate to COM15 from a PC Developer app using a Serial Port component. But I don't know how you would access the same serial connection from within Embedded code in the device itself.
Has thanked: 443 times
Been thanked: 604 times
Please can you send us a link to the specific board you're using.
Looks for devices like this to do comms back to the PC would require a USB component. Might not be too hard thanks to the IDF so I'll get it on the list.
Hi ben
Link to the specific board:
https://docs.m5stack.com/en/core/AtomS3
Link to a shop:
https://www.digikey.ch/de/products/deta ... 3/17751546
Demo with display (working in SPI softwaremode) :)
S3_24_1_demo.fcfx
(17.54 KiB) Downloaded 10 times
That looks great, are you able to program the screen? Do we need a new component for it?
I've just bought myself one and also got a couple more M5 boards. Unfortunatley they look like they might take a while to get here.
For the Atom S3 the component gLCD_ST7789V1 is working to display text.
The Atom matrix has a 5x5 LED Matrix and it's working with FC WS2812C
For the M5 Dial knob I think an additional component for GC9A01A Display driver is necessary.
The display is also used by other manufacturers
A very good feature of these M5 stack modules is that the IMU MPU6886 is supported von FC
