App developer; for analyzing data in batch mode
Has thanked: 150 times
Been thanked: 171 times
App developer is very well suited to converting or analyzing measurement data files with a large number of measurement results.
However, this sometimes takes several minutes
With the App developer it is not so easy to select a file because there is no file open menu in the app developer.
So the idea to rename the measurement data file to 1.wav; 2.wav; 3.wav
If the file name is already known, you can also write the app in such a way that first file 1, then file 2 and then file 3 is opened automatically
and the App, analyzes and saves the results automatically.
The results from the 3 files can also be automatically saved into
files 1.csv 2.csv and 3.csv
or written into a single 123.csv file
Now I have more files in different folders (always 3 files)
I copy the finished App (just a few kbytes) into each folder
And then start my batch file. (start_all.bat)
All 6 Apps are started and run at the same time
Time to drink coffee...
When I get back I quickly look at the results on the app and then close the app.
Now the question:
Is it possible to call up the App with parameters in the future?
I mean from the batch file with this command
EMG_recorderfile_read.mscada 1.wav
Or the App opens all the .WAV files in the folder and analyzes them.
We already do it this way with other programs.
Saves a lot of time....
start_all.bat
start C:\ZZM\FC9_Test\sensor_1\EMG_recorderfile_readmulti3.mscada
start C:\ZZM\FC9_Test\sensor_2\EMG_recorderfile_readmulti3.mscada
start C:\ZZM\FC9_Test\sensor_3\EMG_recorderfile_readmulti3.mscada
start C:\ZZM\FC9_Test\sensor_4\EMG_recorderfile_readmulti3.mscada
start C:\ZZM\FC9_Test\sensor_5\EMG_recorderfile_readmulti3.mscada
start C:\ZZM\FC9_Test\sensor_6\EMG_recorderfile_readmulti3.mscada
Has thanked: 168 times
Been thanked: 279 times
Re: App developer; for analyzing data in batch mode
Good suggestion, Stefan. I've added it to my list.
