add slider command as windows
solozerouno
Has thanked: 2 times
Been thanked: 2 times
Post by solozerouno »
Please add slider command to control app developer.....
thanks solozerouno
Has thanked: 516 times
Been thanked: 474 times
Re: add slider command as windows
There is a Linear Slider which can be horizontal or vertical
The scale can be changed and you can have a Static Text component displaying the value.
Although the variable type for the slider is float, it will work with bytes integer, longs etc.
Linear Slider.png (12.13 KiB) Viewed 1593 times
