16F18877(AD) chip is faulty!
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 16F18877(AD) chip is faulty!
Post by niedian »
16F18877(AD) in practice, or in proteus,They don't work properly.itdoes not work properly after compilation in V8,V9,V10 Version .
16F18877.fcfx
(10.63 KiB) Downloaded 772 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: 16F18877(AD) chip is faulty!
Post by p.erasmus »
Try to use the help file(wiki) when using components for the AD component you need to enable the ADC on the chip before using it see screen print below
Try it and let us know how you get along
niedian
Post by niedian »
solved!
Has thanked: 647 times
Been thanked: 856 times
This shouldn't be the case. The Raw enable should already be being called as part of the GetByte routine.
This the code for the GetByte function.
And the RawEnable for comparison.
Niedian, you say solved can you say what did you do to solve the issue? Was it as Peter described?
p.erasmus
Post by p.erasmus »
I had now two simple projects that the ADC did not work without calling the RAW enable Macro might be good Idea to check this
Thanks Peter,
Can you check your C code matches the code shown above.
p.erasmus
Post by p.erasmus »
OK I will check when I am back at the lab
p.erasmus
Post by p.erasmus »
Ok I see with the getbyte the ADC gets enabled however in my code I use RawSampleInt and AverageSamples and in the C code functions the ADC is not enabled and I asumed it was the case for getByte as well Sorry I mislead the person with my comments however I was sure I had to use RawEnable
my appoligise
would be interesting if he tell us how hesolved the issue.
Hello Peter,
Aha yes for the RawSample you need to enable first :) ok that explains things and glad to know it's not a problem.
Interested as to how Niedian solved their issue.
niedian
Post by niedian »
The same old problem. unsolved
