when I try to copmpile a code I get following error
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
using updated 32-bit floating-point libraries; improved accuracy might increase code size
(908) exit status = 1
Error returned from [xc8.exe]
Autoclose turned off
chip: PIC18F23K22
PROGRAMMER : PICKIT3
Also in simulation I get no sensors data ...maybe there are mistakes in the code..any help?
FC10 COMPILE ERROR FOR SENSORS COMPONENTS
SILVESTROS
- Has thanked: 32 times
- Been thanked: 2 times
- PIC18F23K22-SENSORS-DATA1.fcfx
- (21.25 KiB) Downloaded 283 times
- Has thanked: 163 times
- Been thanked: 960 times
Re: FC10 COMPILE ERROR FOR SENSORS COMPONENTS
There is insufficient RAM for the esp8266 component to allocate an array:
To answer my own question - 512 bytes - looking at the wlan_esp8266 component -it seems to allocate quite a large amount of RAM as global variables (not sure why the 100 char scannames needs 180 bytes ?)
There are also, for example, 10 x outN[20] strings so either 200 or 360 bytes gone here...
So the easy fix - change to a MCU with more RAM.
The harder fix - it might be possible to modify the component to use less memory?
How much RAM does the 18F23K22 have?G:\Downloads\PIC18F23K22-SENSORS-DATA1.h: 408: (1250) could not find space (180 bytes) for variable _FCV_08181_WLAN_ESP8266__SCANNAMES
SILVESTROS
ok, PIC18F23K22 has 8K FLASH, 512 byte SRAM..I change with PIC18F25K22 that has 32K FLASH, 1536 byte SRAM...compile is ok, but in hardware not work...I get no data in variables...there is something wrong with code , or in sensors components ? maybe at code I think..can you check the code for errors?
- Has thanked: 442 times
- Been thanked: 661 times
SILVESTROS
Yes, today I saw your reply...thanks...I've a problem with my network...
