PCF8574 component macro error in V10
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 PCF8574 component macro error in V10
Post by niedian »
Data output error after compilation in V10. That's true in V8.
PCF8574.fcfx
(23.99 KiB) Downloaded 457 times
niedian
The PCF8575 component macro has an error in V10
Post by niedian »
The PCF8575 Data output error after compilation in V10. That's true in V8.
PCF8575并口扩展芯片的流码设计.fcfx
(8.18 KiB) Downloaded 398 times
Has thanked: 724 times
Been thanked: 783 times
Re: PCF8574 component macro error in V10
I have just tested a PCF8574T
Sent data in a repeated loop of 1, 2 & 4 and the correct pins P0, P1 & P2 are at the correct logic of 100, 010, 001,100, 010 & 001 etc.
Can you explain the difference in data expected and what you got?
I have noticed in your PCF8574.fcfx project you posted, none of the expanders have their Device Type selected within properties.
You will need to select either PCF8574 or PCF8574A as they have different addresses.
It could be the wrong addresses are being used.
niedian
Post by niedian »
It's perfect. Thank you!
I'm glad your project is working now does that include the PCF875 as well?
As it was not a bug I will move the topic from the bugs section.
Thank you for updating us.
