I have run into a problem compiling for ESP32 glcd PCD85442. The result is always the same...
ninja failed with exit code 1
I have tried with a different display and everything compiles OK.
So there seems to be a problem with the ESP32 glcd PCD85442 combination.
I hope you can help.
Pete
ESP32 glcd PCD85442
Ferretlove
- Been thanked: 1 time
ESP32 glcd PCD85442
- Nikia Display Try.msg.txt
- (151.72 KiB) Downloaded 563 times
- Nikia Display Try.fcfx
- (11.95 KiB) Downloaded 586 times
- (view online)
- Has thanked: 796 times
- Been thanked: 858 times
Re: ESP32 glcd PCD85442
Thank you for letting us know.
Unfortunately, the ESP32 is fussier than other types of microcontrollers.
I have fixed the component and will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
If you run any component updates, then the components you added will be overwritten with the updated version.
Can you let me know how it goes, please?
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- gLCD_PCD8544.fcpx
- (12.34 KiB) Downloaded 507 times
Ferretlove
Thank you for you quick reply.
From reading the forum I understand the ESP is a finicky beast.
I have followed your instructions and deleted and replaced the fcpx file you have supplied, and refreshed my Flowcode, Unfortunately
the problem still persists.
I have attached the new build log.
Pete
Pete
- (3.2 KiB) Downloaded 494 times
Ferretlove
Maybe I'm jumping the gun here. the hidden V10 components is still showing a date of 28/11/2022, 12:15:12. Do I have to wait for that to update?
Ferretlove
I tried the fcpx you posted as an attachment but unfortunately it didn't work.
- (3.2 KiB) Downloaded 458 times
The error you reported is gone as I had the same error before the component update.
Now when I compile your project with the updated component I get:
A suggestion.
Rather than using My Documents folder, create a new folder e.g C:\My Flowcode Projects
Move your project to the new folder and try again
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat "C:\esp-idf\" "Nikia Display Try" "D:\Flowcode Testing\" esp32s_sdkconfig
D:\Flowcode Testing>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB6EFB7F8B9768FC390BAFB420BC9D6F4D56375EE3039B8BDDEA4D1C56CD1580BF569DAEA777BB49732B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EEB3E11C07C6C54039FF3C81C780D7ABB89002782687B4F007BB7835FE546B805B7544DA781CA69696
D:\Flowcode Testing>REM REVISION: 2.0
D:\Flowcode Testing>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
D:\Flowcode Testing>REM DATE: 05\12\2022
D:\Flowcode Testing>REM DIR: FCD\ESP\Batch\esp32_build.bat
============================== Toolchain Check ==============================
Python 3.7.3
git version 2.21.0.windows.1
ESP toolchain found at "C:\esp-idf\"
Building Nikia Display Try ...
Setting IDF_PATH: C:\esp-idf
Adding ESP-IDF tools to PATH...
C:\esp-idf-tools\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\esp-idf-tools\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\esp-idf-tools\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\esp-idf-tools\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\esp-idf-tools\tools\cmake\3.13.4\bin
C:\esp-idf-tools\tools\openocd-esp32\v0.11.0-esp32-20211220\openocd-esp32\bin
C:\esp-idf-tools\tools\ninja\1.9.0\
C:\esp-idf-tools\tools\idf-exe\1.0.1\
C:\esp-idf-tools\tools\ccache\3.7\
C:\esp-idf-tools\python_env\idf4.1_py3.7_env\Scripts
C:\esp-idf\tools
Python requirements from C:\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
[1/69] Linking CXX static library esp-idf\app_trace\libapp_trace.a
[2/69] Linking CXX static library esp-idf\cxx\libcxx.a
[3/69] Linking CXX static library esp-idf\newlib\libnewlib.a
[4/69] cmd.exe /C "cd /D D:\Flowcode_Testing\Nikia_Display_Try\build\esp-idf\partition_table && C:\esp-idf-tools\tools\cmake\3.13.4\bin\cmake.exe -E echo "Partition table binary generated. Contents:" && C:\esp-idf-tools\tools\cmake\3.13.4\bin\cmake.exe -E echo ******************************************************************************* && C:\esp-idf-tools\python_env\idf4.1_py3.7_env\Scripts\python.exe C:/esp-idf/components/partition_table/gen_esp32part.py -q --offset 0x8000 --flash-size 2MB D:/Flowcode_Testing/Nikia_Display_Try/build/partition_table/partition-table.bin && C:\esp-idf-tools\tools\cmake\3.13.4\bin\cmake.exe -E echo *******************************************************************************"
# Espressif ESP32 Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[5/69] Linking CXX static library esp-idf\vfs\libvfs.a
[6/69] Performing build step for 'bootloader'
ninja: no work to do.
[7/67] Linking CXX static library esp-idf\freertos\libfreertos.a
[8/67] Linking CXX static library esp-idf\heap\libheap.a
[9/67] Linking CXX static library esp-idf\log\liblog.a
[10/67] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
In file included from ../main/esp-project.c:38:
C:/esp-idf/components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:110,
from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:568,
from ../main/esp-project.c:48:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_Float.c:91:6: warning: conflicting types for built-in function '__builtin_isinf_sign' [-Wbuiltin-declaration-mismatch]
char isinf(float f)
../main/esp-project.c: In function 'FCD_09e54_gLCD_Font4__ReadWidth':
../main/esp-project.c:403:11: warning: unused variable 'FCL_PWIDTH' [-Wunused-variable]
MX_UINT8 FCL_PWIDTH;
../main/esp-project.c:402:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
MX_UINT16 FCL_POSITION;
../main/esp-project.c: In function 'FCD_09e53_gLCD_Font3__ReadWidth':
../main/esp-project.c:693:11: warning: unused variable 'FCL_PWIDTH' [-Wunused-variable]
../main/esp-project.c:692:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_09e52_gLCD_Font2__ReadWidth':
../main/esp-project.c:983:11: warning: unused variable 'FCL_PWIDTH' [-Wunused-variable]
../main/esp-project.c:982:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_09e51_gLCD_Font1__SumWidths':
../main/esp-project.c:1225:11: warning: unused variable 'FCL_WIDTH' [-Wunused-variable]
MX_UINT8 FCL_WIDTH;
../main/esp-project.c: In function 'FCD_09e51_gLCD_Font1__ReadWidth':
../main/esp-project.c:1256:11: warning: unused variable 'FCL_PWIDTH' [-Wunused-variable]
../main/esp-project.c:1255:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_0ba71_Base_GLCD__ReadFontStat':
../main/esp-project.c:1512:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_0ba71_Base_GLCD__ReadFontByte':
../main/esp-project.c:1577:12: warning: unused variable 'FCL_POSITION' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_076e1_gLCD_PCD85442__Print':
../main/esp-project.c:2583:11: warning: unused variable 'FCL_H' [-Wunused-variable]
MX_UINT8 FCL_H;
../main/esp-project.c: In function 'FCD_076e1_gLCD_PCD85442__Initialise':
../main/esp-project.c:3205:11: warning: unused variable 'FCL_BLUE' [-Wunused-variable]
MX_UINT8 FCL_BLUE;
../main/esp-project.c:3204:11: warning: unused variable 'FCL_GREEN' [-Wunused-variable]
MX_UINT8 FCL_GREEN;
../main/esp-project.c:3203:11: warning: unused variable 'FCL_RED' [-Wunused-variable]
MX_UINT8 FCL_RED;
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:568,
At top level:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:876:13: warning: 'FCI_SCOPY' defined but not used [-Wunused-function]
static void FCI_SCOPY(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:815:13: warning: 'FCI_SHEAD' defined but not used [-Wunused-function]
static void FCI_SHEAD(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:795:18: warning: 'FCI_STRMOV' defined but not used [-Wunused-function]
static MX_UINT16 FCI_STRMOV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:771:18: warning: 'FCI_STRREV' defined but not used [-Wunused-function]
static MX_UINT16 FCI_STRREV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:701:17: warning: 'FCI_STRING_TO_FLOAT' defined but not used [-Wunused-function]
static MX_FLOAT FCI_STRING_TO_FLOAT(MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:598:18: warning: 'FCI_NUMBER_TO_HEX' defined but not used [-Wunused-function]
static MX_STRING FCI_NUMBER_TO_HEX(MX_ULONG Number, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:531:18: warning: 'FCI_FLOAT_TO_STRING' defined but not used [-Wunused-function]
static MX_STRING FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:476:17: warning: 'FCI_COMPARE' defined but not used [-Wunused-function]
static MX_UINT8 FCI_COMPARE(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_UINT8 iNoCase)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:450:13: warning: 'FCI_TOUPPER' defined but not used [-Wunused-function]
static void FCI_TOUPPER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:424:13: warning: 'FCI_TOLOWER' defined but not used [-Wunused-function]
static void FCI_TOLOWER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:331:10: warning: 'FCI_TOSTRU32' defined but not used [-Wunused-function]
MX_UINT8 FCI_TOSTRU32(MX_UINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:297:10: warning: 'FCI_TOSTRU16' defined but not used [-Wunused-function]
MX_UINT8 FCI_TOSTRU16(MX_UINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:254:10: warning: 'FCI_TOSTRS32' defined but not used [-Wunused-function]
MX_UINT8 FCI_TOSTRS32(MX_SINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:211:10: warning: 'FCI_TOSTRS16' defined but not used [-Wunused-function]
MX_UINT8 FCI_TOSTRS16(MX_SINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:182:18: warning: 'FCI_RIGHTSTRING' defined but not used [-Wunused-function]
static MX_STRING FCI_RIGHTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:159:18: warning: 'FCI_LEFTSTRING' defined but not used [-Wunused-function]
static MX_STRING FCI_LEFTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:129:18: warning: 'FCI_MIDSTRING' defined but not used [-Wunused-function]
static MX_STRING FCI_MIDSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iStart, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_String.c:113:17: warning: 'FCI_GETCHAR' defined but not used [-Wunused-function]
static MX_UINT8 FCI_GETCHAR(MX_STRING sStr1, MX_UINT16 iStr1_len, MX_UINT16 iPos)
[11/67] Linking CXX static library esp-idf\lwip\liblwip.a
[12/67] Linking CXX static library esp-idf\esp_wifi\libesp_wifi.a
[13/67] Linking CXX static library esp-idf\wpa_supplicant\libwpa_supplicant.a
[14/67] Linking CXX static library esp-idf\esp_event\libesp_event.a
[15/67] Linking CXX static library esp-idf\esp_netif\libesp_netif.a
[16/67] Linking CXX static library esp-idf\tcpip_adapter\libtcpip_adapter.a
[17/67] Linking CXX static library esp-idf\esp_eth\libesp_eth.a
[18/67] Linking CXX static library esp-idf\soc\libsoc.a
[19/67] Linking CXX static library esp-idf\esp_rom\libesp_rom.a
[20/67] Linking CXX static library esp-idf\esp_common\libesp_common.a
[21/67] Linking CXX static library esp-idf\esp32\libesp32.a
[22/67] Linking CXX static library esp-idf\perfmon\libperfmon.a
[23/67] Linking CXX static library esp-idf\espcoredump\libespcoredump.a
[24/67] Linking CXX static library esp-idf\pthread\libpthread.a
[25/67] Linking CXX static library esp-idf\nvs_flash\libnvs_flash.a
[26/67] Linking CXX static library esp-idf\driver\libdriver.a
[27/67] Linking CXX static library esp-idf\efuse\libefuse.a
[28/67] Linking CXX static library esp-idf\bootloader_support\libbootloader_support.a
[29/67] Linking CXX static library esp-idf\mbedtls\mbedtls\library\libmbedtls.a
[30/67] Linking CXX static library esp-idf\mbedtls\mbedtls\library\libmbedx509.a
[31/67] Linking CXX static library esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a
[32/67] Linking CXX static library esp-idf\spi_flash\libspi_flash.a
[33/67] Linking CXX static library esp-idf\app_update\libapp_update.a
[34/67] Linking CXX static library esp-idf\esp_ringbuf\libesp_ringbuf.a
[35/67] Linking CXX static library esp-idf\xtensa\libxtensa.a
[36/67] Linking CXX static library esp-idf\asio\libasio.a
[37/67] Linking CXX static library esp-idf\bt\libbt.a
[38/67] Linking CXX static library esp-idf\cbor\libcbor.a
[39/67] Linking CXX static library esp-idf\coap\libcoap.a
[40/67] Linking CXX static library esp-idf\console\libconsole.a
[41/67] Linking CXX static library esp-idf\esp_adc_cal\libesp_adc_cal.a
[42/67] Linking CXX static library esp-idf\esp_gdbstub\libesp_gdbstub.a
[43/67] Linking CXX static library esp-idf\esp_https_ota\libesp_https_ota.a
[44/67] Linking CXX static library esp-idf\protobuf-c\libprotobuf-c.a
[45/67] Linking CXX static library esp-idf\sdmmc\libsdmmc.a
[46/67] Linking CXX static library esp-idf\esp_websocket_client\libesp_websocket_client.a
[47/67] Linking CXX static library esp-idf\expat\libexpat.a
[48/67] Linking CXX static library esp-idf\wear_levelling\libwear_levelling.a
[49/67] Linking CXX static library esp-idf\freemodbus\libfreemodbus.a
[50/67] Linking CXX static library esp-idf\jsmn\libjsmn.a
[51/67] Linking CXX static library esp-idf\json\libjson.a
[52/67] Linking CXX static library esp-idf\mqtt\libmqtt.a
[53/67] Linking CXX static library esp-idf\mdns\libmdns.a
[54/67] Linking CXX static library esp-idf\libsodium\liblibsodium.a
[55/67] Linking CXX static library esp-idf\openssl\libopenssl.a
[56/67] Linking CXX static library esp-idf\spiffs\libspiffs.a
[57/67] Linking CXX static library esp-idf\unity\libunity.a
[58/67] Linking CXX static library esp-idf\protocomm\libprotocomm.a
[59/67] Linking CXX static library esp-idf\esp_serial_slave_link\libesp_serial_slave_link.a
[60/67] Linking CXX static library esp-idf\fatfs\libfatfs.a
[61/67] Linking CXX static library esp-idf\esp_local_ctrl\libesp_local_ctrl.a
[62/67] Linking CXX static library esp-idf\wifi_provisioning\libwifi_provisioning.a
[63/67] Linking CXX static library esp-idf\main\libmain.a
[64/67] Generating ld/esp32.project.ld
[65/67] Building C object CMakeFiles/esp-project.elf.dir/project_elf_src.c.obj
[66/67] Linking CXX executable esp-project.elf
[67/67] Generating binary image from built executable
esptool.py v2.9-dev
Generated D:/Flowcode_Testing/Nikia_Display_Try/build/esp-project.bin
Running ninja in directory d:\flowcode_testing\nikia_display_try\build
Executing "ninja all"...
Project build complete. To flash, run this command:
C:\esp-idf-tools\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp-idf\components\esptool_py\esptool\esptool.py -p (PORT) -b 460800 --before default_reset --after hard_reset --chip esp32 write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 build\bootloader\bootloader.bin 0x8000 build\partition_table\partition-table.bin 0x10000 build\esp-project.bin
or run 'idf.py -p (PORT) flash'
Build completed successfully
Ferretlove
Hi.
I will give that a try, more than likely I have got something wrong.
I will let you know.
Thank you.
Pete.
Thank you.
Pete.
Ferretlove
Hi There.
You're my hero
Thank you very much. I'm one very happy bloke.
It compiled perfectly and loaded to my test circuit, The display is now counting!
Once again. Thank you very much for your help.
Pete.
You're my hero
Pete.
