Unable to read data from Accel Gyro 6_Axis LSM6DS3
Emad2023
Has thanked: 1 time
Post by Emad2023 »
I can't able to read data from Accel Gyro 6_Axis LSM6DS3 (105020012) component. I'm using BL0080 - 8-Bit PIC Multi-Programmer. I connected the SDA and SCL to the right pins in flowcode. However, all my trial fail.
Kindly, find the attached files for more info.
Grove Accel Gyro Combo BL0114.fcfx
(14.41 KiB) Downloaded 700 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Unable to read data from Accel Gyro 6_Axis LSM6DS3
Post by p.erasmus »
HI,
Just a quick question do you have pull resistors fitted to the SDA and SCL lines ?
Has thanked: 772 times
Been thanked: 833 times
Please don't post multiple posts asking the same question.
So we know what Flowcode version you have, we recommend starting topics with one of these post icons:
Post Icons.png (8.36 KiB) Viewed 5829 times
It saves us from asking what version you have.
What version of Flowcode do you have?
Emad2023
Has thanked: 1 time
Flowcode v10 Re: Unable to read data from Accel Gyro 6_Axis LSM6DS3
Post by Emad2023 »
Regarding to Mr. p.erasmus question, No, I don't connect a pull up resistors between SDA and SCL lines. Because, I think that they had already existed in the Accel Gyro 6_Axis LSM6DS3 board.
Hello, I have developed a Project just for your situation.
Can you compile and run the attached project and let me know what the display shows, please?
Ignore any warning that This project was built with a newer version.
IC2 Address Sniffer EB00011 Combo v1a.fcfx
(25.25 KiB) Downloaded 719 times
Emad2023
Has thanked: 1 time
Post by Emad2023 »
Thank you Mr. medelec for your cooperation. The address for the Accel Gyro 6_Axis LSM6DS3 board is the same as I configured.
I think there is another issue !!
