App Developper: switch on keyboard
Has thanked: 245 times
Been thanked: 256 times
Flowcode v10 App Developper: switch on keyboard
On my program I have 2 switch.
To press this switch with the mouse or mousepad is working nice.
is there a way to control this switch with the computer keyboard?
As a sample: if i press the key R or F11 it will record and if I press the key s or F12 it will stop the recording
Has thanked: 174 times
Been thanked: 996 times
Re: App Developper: switch on keyboard
Post by mnfisher »
It's easy to do using the keyboard monitor component.
There is a simple example in the wiki at https://www.flowcode.co.uk/wiki/index.p ... _Control_)
Has thanked: 300 times
Been thanked: 465 times
I have another solution that does not need an additional component or code. Use "Key mapping" which is available in the "Edit" menu. Attached is an example, which also uses the new "Macro called" feature of switches.
button press app.mscada
(4.32 KiB) Downloaded 423 times
button press app.fcsx
(15.05 KiB) Downloaded 447 times
Hi Martin, Hi Steve
I have tried the example from the wiki but it does not work properly.
up/dwn moves the position of the button. I did not manage to correct this, but then FC10 froze.
I have understood and modified Steve's example and it works fine.
Thanks to both
button press app_v2.fcsx
(13.03 KiB) Downloaded 461 times
