Calculation
iangm
Calculation
if test =0 and you add 0.02 test then becomes 0.2. if you carry on then test becomes 0.4, 0.6, 0.8 and then o.1. why does this happen? If test is increased by 0.2 then the values of test printed out are correct. if test is increased by 0.02 then the first few values are wrong. PrintLine and PrintString are correct
- Main1.JPG (24.98 KiB) Viewed 1792 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: Calculation
As you have not used a 9 or 10 post icon I'm assuming you are using FC10.
Are you referring to simulation or hardware?
Just checked the simulation and:
That is what I would expect.
We can't take things further unless you do what kersing has suggested.
As this is nothing to do with user components, I have moved the topic to the general section.
- test plus 0.02.png (41.17 KiB) Viewed 1809 times
