Thanks - I'll continue with my 'combined' component for now....
Note that using MX_SPI_CHANNEL_IN_USE = 1 as above does seem to solve the transmit problem - though would need to alter the redirect for initialise - the 'second' component using the channel could just redirect to an empty routine - though this might cause issues if it is initialised first and used before the 'first' component?
Thinking aloud:
I wondered - though it would entail a fair amount of change - why the CAL_SPI routines don't just 'pass' a channel number. This would remove the duplication of code at the expense of an extra parameter and some extra storage in the backend code.
So in (very) pseudocode:
CAL_SPI_1::SPI_Master_Byte(123) in the component code would call SPI_SendByte(1, 123)
The SPI backend code would have (possibly) an array of SPI channel details (setup per channel on initialise) - and then, for example,
SPI_SendByte(channel, data) {
SPIDetails *dat = SPIDat[channel];
Use values from dat...
Though it might be just as easy to code it all in FC - and have the component do all the work?
Another aside - some topics (this, for example) - I don't get notifications for. Others I do (even if I've not posted) - and will a notification for any new post. Is there a setting for this?
ILI9341 & XPT2046 Touchscreen
- Has thanked: 162 times
- Been thanked: 952 times
- Has thanked: 615 times
- Been thanked: 809 times
Re: ILI9341 & XPT2046 Touchscreen
I'll have another go for you today and see if I can find a better solution.
Edit, I've pushed a new CAL file that hopefully will now work and do what we want. Let me know.
I like your proposal Martin, I might have an explore of this idea as currently it's not really as efficient as I would like.
The Spanner dropdown at the bottom / top of the page has a subscribe feature that might do what you want?Another aside - some topics (this, for example) - I don't get notifications for.
jgu1
- Has thanked: 833 times
- Been thanked: 205 times
Hi both!
After update I try config the pinconnection in program and in hardware. Not working, get error. Disaster, I am also not able to program other of my project´s with Ili9341 and ESP32 any more
Please Benn, rool back again
Br Jorgen
Br Jorgen
- StandardIli9341FirsSameSpi.msg.txt
- (3.01 KiB) Downloaded 542 times
- StandardIli9341FirsSameSpi.fcfx
- (28.26 KiB) Downloaded 634 times
Hi Jorgen,
- That compiles fine for me... Something awry - you are getting
Strange?
So giving up straight away with a compiler option error....idf.py build
Usage: idf.py [OPTIONS] COMMAND1 [ARGS]... [COMMAND2 [ARGS]...]...
Try 'idf.py --help' for help.
Error: No such option: --no-hints Did you mean --no-warnings?
Strange?
jgu1
Hi MArtin!
I am totally confused now, I can´t compile anything with esp32 on any of my laptop. I have just try to made a new simple testprogram program, will also not compile??
None of my old project either, I am confused???
Please have a look in the txt file, and help
- NotWork.msg.txt
- (1.93 KiB) Downloaded 607 times
- NotWork.fcfx
- (7.1 KiB) Downloaded 560 times
Hi Jorgen,
Looks like your esp installation has gone AWOL? Anything else changed - check the esp directory and run install.bat and check that FC still points to the right directory...
jgu1
Hello, Martin
I'm glad it works for you.
I really can't understand that I suddenly can't compile Esp deviceses. A short time ago I had problems with Starm and was recommended by Leigh to install this Starm compiler : File name: en.stsw-link004.zip from here :https://stm32-st-link-utility.software. ... ownloading do
and install the compiler, after that my Starm could compile, do you think that has an influence on the ESP compiler. I have not moved around any lib.
The error:
Building NotWork ...
'"C:\Users\45505\.espressif\export.bat"' is not recognized as an internal or external command,
'idf.py' is not recognized as an internal or external command,
I have seach for the export.bat" In the expressif lib, but it is not there. Can you see it in your Lib? Please
Please help.
I'm so sorry I suddenly can't compile ESP anymore, I have projects that I've spent many hours on and one of them isn't finished yet
Thank´s in advance
Jorgen
The error:
Please help.
Thank´s in advance
Jorgen
