what hardware works for HC05 Bluetooth
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 what hardware works for HC05 Bluetooth
Post by SpeedPIC32 »
Hello, who can tell me what hardware runs with all functions?
Where do you get these modules.
with kind regards
SpeedPic32
Has thanked: 430 times
Been thanked: 647 times
Re: what hardware works for HC05 Bluetooth
Post by chipfryer27 »
What specific functions are you after? as most modules I've seen are pretty similar in features.
I've had good results using these modules
https://www.amazon.co.uk/AZDelivery-Blu ... to_dp&th=1
However I was only interested in creating a transparent link between them, which worked with ease.
SpeedPIC32
Many thanks chipfryer27
can the module from AZ communicate in both directions?
I ordered some and I had one similar to this. it looks so similar ber works only in one direction.
it sends to the smartphone via bluetooth but not back from the smartphone. the two chips on the module have the same names. can it be that they react differently?
the AT commands for example also do not work as specified.
with kind regards
SpeedPic32
I can confirm bidirectional communications using these modules and I've not had any issue with AT's. My last play with them is here
https://www.flowcode.co.uk/mmforums/view ... 68&t=23028
Do note that depending on vendor, the baud when configuring may be different to the usual 38400.
