Hi everyone
I still have problems compiling code with WiFi and NTP time on esp WiFi kit 32. I can control outputs and write to display ok. All libraries and software upto date.
Wayne M
Problems compiling
wayne_millard
- Has thanked: 1 time
- Been thanked: 9 times
- Has thanked: 397 times
- Been thanked: 608 times
Re: Problems compiling
I'm guessing this is a follow on to previous posts?
As a few others can compile OK (at least to Hex) it would appear that perhaps the issue is local to your installation. Can you try and narrow it down a bit?
Could you create a simple chart that does compile then add in each component in turn? That may help point to the issue.
wayne_millard
I have done this. I can control outputs and write to LCD this is ok.
I have added WiFi Comms as read said and it fails also added NTP time with WiFi and fails to compile.
Wayne m
Wayne m
