The idf.py build seemed to run okay
So tried to compile to chip again but still does not compile to chip
Have enclosed compiler message file
David
ESP32 not compling to chip
DAVIDJOINER
- Been thanked: 18 times
DAVIDJOINER
Re: ESP32 not compling to chip
Enclosed as requested note it is the most basic ie just begin & end just to test compiling to chip
David
David
- ESP32_TEST5.fcfx
- (5.82 KiB) Downloaded 1017 times
- (view online)
LeighM
- Has thanked: 110 times
- Been thanked: 302 times
Hi David,
Could you now try this in the cmd prompt
Then post the LOG.TXT file
cd C:\FLOWCODE9\ESP32_TEST5
idf.py build > LOG.TXT
DAVIDJOINER
Enclosed LG.TXT file as requested
David
David
- LOG.TXT
- (8.99 KiB) Downloaded 868 times
LeighM
Thanks.
Next ... could you run a clean cmd prompt, not the ESP-IDF one, and type this ...
and post XLOG.TXT
Leigh
cd C:\esp-idf
export.bat > XLOG.TXT
Leigh
DAVIDJOINER
XLOG.TXT as requested
David
David
- XLOG.TXT
- (1.91 KiB) Downloaded 933 times
DAVIDJOINER
hI
Sorry ignore last reply as still had set using idf prompt
Have re run again with a clean prompt and ZIP file of the command response
- Capture_prompt.GIF (29.69 KiB) Viewed 14340 times
LeighM
Thanks.
Based on that I think the issues are related to the user "david main" and the space.
Is it possible for you to create a new user on the PC without a space in the name,
then try a re-install of the Espressif installer
DAVIDJOINER
Thats a pest
Note I am using Windows 10
Is it possible to easily rename the user in Windows rather than create a new user (ie deleting any spaces)
Also If i must create a new user do i have re install all of flowcode again as well into it
David
Thats a pest
David
