hi team
I have a problem with the modbus, in practice the data I receive are not true, at the beginning they are correct but after a while they start to round starting from the decimals up to the units, which setting am I doing wrong? I made a test flowchart, in video 1 you can see that the decimals are read, in 2 they are at 0
Thank you
MODBUS PROBLEM
max.tisc
- Been thanked: 12 times
MODBUS PROBLEM
- 2.zip
- (4.41 MiB) Downloaded 210 times
- 1.zip
- (1.88 MiB) Downloaded 223 times
- test modbus.fcfx
- (19.92 KiB) Downloaded 214 times
- Has thanked: 616 times
- Been thanked: 815 times
Re: MODBUS PROBLEM
I beleive this is the problem, the float is being broken up into two 16-bit values but then both values are being stored to the same 16-bit modbus register.
This means on the other end you are only getting half of the bits of the float variable.
Re: MODBUS PROBLEM
Thanks Ben, I've been looking around for 2 days, sorry if I wasted your time for this nonsense that I hadn't noticed, now it's working fine
you are always the best
thanks
thanks
Re: MODBUS PROBLEM
No problem, happy to help.
Many thanks for letting us know and glad it's working correctly for you now.
