Back to a few weeks ago courtesy of "CE" (aka Chinese Export).
A colleague has an impressive amount of battery powered tools by a major, well respected brand. Unfortunately at some point he bought a non brand battery. I've no idea of the make, age or anything else and now impossible to tell. It apparently had all the necessary connections for the charger to operate but who knows the quality of anything inside...!
He put it on charge, in branded charger and all was good. Was...... a "kaboom" later and it's raining fiery shrapnel.... Nowhere in the Evil Lab are you more than a couple of metres from a fire extinguisher of appropriate type, so no real possibility of a fire starting and catching hold, but appropriate type for a Lithium battery is powder..... That is messy, but well, well worth it and I urge all to have one at hand.
As mentioned, they are messy so I will be continuing to clean up the mess for the next few days. My TRS-80 was near-ish and now looks like it was the star in a Head & Shoulders advert prior to use..... A multimeter looks like I rescued it from Pompeii.....
Needs a clean since you last saw it....
- 100_0193.JPG (71.92 KiB) Viewed 4220 times
As documented, the TRS-80 has open keys, so there is a strong chance that the dust is now inside the keys. I'm hoping the vacuum will pull most out, but it needs to be stripped to be sure. Same with the monitor once I dig it out. Good job I now know which screws go where.
Meter.... I think...
- 100_0195.JPG (102.34 KiB) Viewed 4220 times
This did serve as a harsh warning to my colleague, to never buy non brand Lithium from cheap sources. If you have never seen one go kaboom, keep hoping you never do. It is without any wonder that many electric vehicles such as scooters, hoverboards (stupid name) etc are banned on public transport. It's for a reason.
It is worth noting that you can now get an extinguisher tailored for Lithium from Screwfix (UK trade store, other stores will have them too) which has (I think) a suspended vermiculite which encapsulates the battery and cells inside, helping to prevent further thermal runaway and more kabooms.
