RP2040 ram and rom usage?
Chadb
Has thanked: 32 times
Been thanked: 1 time
Re: RP2040 ram and rom usage?
Post by Chadb »
Oh, and pin25 isn't defined in the PICO file. So I don't think that will work either. It would in the rp2040.
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Hi Chad,
I now have this working (again) :D
The missing link is ...
Step 1
Add pico_multicore to target_link_libraries in CMakeLists.txt
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PICO\batch
target_link_libraries(flowcode pico_stdlib hardware_adc hardware_spi hardware_pwm hardware_i2c pico_multicore)
Step 2
In your project "Supplementary code" -> "Definitions" add the following (Ben: could probably go in the FCDs)
#include "pico/multicore.h"
Step 3
Put the code that you want to run in the second core into a Flowcode macro, e.g. CORE2
Launch it from the following C code icon in the Main macro
multicore_launch_core1(FCM_CORE2);
All done, delete any pre-existing build directory and recompile.
btw. (Using target Pi Pico) For the onboard LED you can use the following in a Calculation icon
$PORTA.25 = 1
edit: Ah, and last but not least, be careful with using two cores, functions aren't necessarily thread safe :roll:
Has thanked: 469 times
Been thanked: 699 times
Post by chipfryer27 »
Hi Leigh
Huge thanks for this, works a treat.
With this extra power surely my world domination is a few steps closer :)
Best regards
PS
Pico Dual Core.jpg (41.5 KiB) Viewed 4347 times
Chadb
Post by Chadb »
That's great! I'll give it a whirl a little later.
Thanks,
Chad
*Edit: Works! Thank you.
