Pico PWM Frequency
Has thanked: 478 times
Been thanked: 713 times
Flowcode v10 Pico PWM Frequency
Post by chipfryer27 »
I've been playing with a Pico when I get time, and there is an issue with the PWM.
If I set it for a frequency of 5KHz then I get an actual frequency of 20Hz
Flowcode PWM=5KHz.jpg (62.49 KiB) Viewed 3169 times
Analyser PWM=20Hz.jpg (30.63 KiB) Viewed 3169 times
Experimenting, if I set the component for a freqency of ~1.288MHz the I can get 5KHz.
Flowcode PWM=1288659Hz.jpg (27.88 KiB) Viewed 3169 times
PWM=5KHz Analyser.jpg (37.08 KiB) Viewed 3169 times
5KHz_PWM.fcfx
(8.79 KiB) Downloaded 387 times
Just thought I'd let you know.
Re: Pico PWM Frequency
It's as if whatever is entered is then shifted >>8
Has thanked: 795 times
Been thanked: 858 times
Hi Iain
Thank you for the report.
I believe I have fixed the frequency for the 10bit PWM.
If you want to use the 10bit, I have attached the modified cal file.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PICO
save the attached CAL in the above location.
Note: As PWM is 16bit, don't use 8bit set duty as the range will be severely limited.
PICO_CAL_PWM.c
(4.8 KiB) Downloaded 346 times
Hi Martin
Thanks, I'll try that tomorrow. I was using the 10-bit option.
Working fine now
PWM Output.jpg (32.51 KiB) Viewed 3112 times
Thanks.
Hi Iain.
That's great, thanks for the update
I will ask for the modified file to be pushed to the update system.
