SHT21
jgu1
Has thanked: 839 times
Been thanked: 205 times
Flowcode v9 SHT21
Post by jgu1 »
Hi!
I have opened an SHT21 project created in FC9, now it is not working, made a test in FC 10 too also not working, pls, what am I doing wrong?
Br Jorgen
SHT21 FC9.fcfx
(13.18 KiB) Downloaded 551 times
SHT21 FC10.fcfx
(14.08 KiB) Downloaded 640 times
Has thanked: 724 times
Been thanked: 783 times
Re: SHT21
Hi Jorgen.
I have just ordered an SHT21, so I can see if I can get it to work.
Has thanked: 163 times
Been thanked: 960 times
Re: SHT21
Post by mnfisher »
Looks like it is an i2c issue - having a display and the sensor on i2c but both using the same channel.
The sensor uses Transaction_Write in Get_Data - but never initialises the i2c to use the correct address. The sensor doesn't seem top have an initialise routine (to init the i2c channel) at all?
jgu1
Re: SHT21
Post by jgu1 »
Hi Martin & Martin!
Thank you both. I'm glad you can also see that something is not working. And mnfisher for the test and troubleshooting :D
@medelec35:
I can send you a SHT21?
If you find an error in the communication and you correct it, it will hopefully not affect other components with the same communication, I see in the past there have been lot of update with the I2C com, and especially not the ILI9488, ILI9341 and st7796 display, I know they use SPI, but anyway, I still work in a project with these display ;)
Br Jorgen
Has thanked: 616 times
Been thanked: 815 times
Re: SHT21
It looks like the initialise function for the SHT21 component was missing from the component export. I've now included it in v10 and so it should be there now if you get the latest library updates.
Hopefully this will solve the issue for you.
jgu1
Re: SHT21
Post by jgu1 »
Hi Ben!
I have just perform a test after update, sorry still not working, Temp -46 and Hum -6
Try to change from SW mode and back again and another device, no luck.
Jorgen
Re: SHT21
Hi Jorgen,
In your program have you added a call to the SHT21 initialise function?
Re: SHT21
I can confirm that after adding initialise, on hardware, the temperature and humidity functions are working as expected.
jgu1
Re: SHT21
Post by jgu1 »
Hi both, so sorry forgot the initialisering, when I come Home, I test and you hear. So many thank’s :D
Br Jorgen
jgu1
Re: SHT21
Post by jgu1 »
Hi again!
Thank you, stupid me, of course I need to add the initialise, work perfeckt now :) will it also be added in FC9 too ;)
Br Jorgen
