ModBus Master Read coil
george_b
Has thanked: 13 times
Been thanked: 3 times
Post by george_b »
For the purpose of a project i need to write and read several bits using read and write coil function of modbus.
I can successfully write to the slave coil status but i can not read the coil status from the slave.
Is there any example using Modbus Master to read coil from a slave?
I would be really grateful for anyone who can give me some help on this one.
Thank in advance!
George
Has thanked: 442 times
Been thanked: 661 times
Re: ModBus Master Read coil
Post by chipfryer27 »
The WiKi is a good starting point.
https://www.flowcode.co.uk/wiki/index.p ... s:_System)
Hope this helps.
george_b
Post by george_b »
Thanks for you reply. I have already checked the examples in wiki page. None of them shows how to read coils while using Modbus Master component!
george_b
Post by george_b »
would it be possible for any member to attach an example of a program reading coil using Modbus Master?
Thanks in advance!
George
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hello?
I program using the 3XXXX Holding Register address.
This advantage is that only one address is used during Modbus communication and there is less error occurrence.
Hope this helps.
george_b
Post by george_b »
Attached is a program thrying to read modbus registers using Modbus Master component.
Note that this program is not working on hardware. Any idea what is wrong ?
George
MODBUS.fcfx
(15 KiB) Downloaded 447 times
The "old" forum has a lot of info re Modbus. Don't know if it will help
https://www.flowcode.co.uk/mmforums/sear ... l&start=25
Also, these Demo's appear to be using coils.
Has thanked: 616 times
Been thanked: 815 times
Hi George,
Looking at your program it appears you're close. Have you done a LED flasher test to confirm things like delays are accurate, this is required to get the communications baud correct.
https://www.flowcode.co.uk/wiki/index.p ... ED_flasher
I've changed a couple of things in your program, firstly to move the delay so that you're not constantly hammering the comms and seconds to change the index for GetResponseInt from 0 to 4 which is the start of the return data.
MODBUS.fcfx
(15 KiB) Downloaded 461 times
Lastly the RegAddress parameter might not be correct, what address are you trying to read?
george_b
Post by george_b »
Hi Ben and thanks for you reply.
I did manage to make it working after a loooot of time trying and trying different things.
Indeed GetResponseInt must be 4 as you said.
RegAddress is correct since the device i am trying to read gives me this registers map .
Thanks again for your support.
George
