Hello together
I have the same problem as before with FC9 end of 2021, that I can't get the USB interface of the PIC32 to work. This time in FC10.
I had assumed that the problem no longer exists in FC10, but we are now in the middle of 2023!
Old programmes from fc9 with USB CDC, compile in fc10 only with error.
I have reinstalled Harmoni1.11 without result. is it better with Harmoni V3?
I would like a batch file that changes everything.
Greetings SpeedPic32
Target folder: C:\Users\uwe\Documents\Daten\Flowcode_Projekte
Source name: C:\Users\uwe\Documents\Daten\Flowcode_Projekte\USB CDC.fcfx
Title:
Description:
Device: PIC32.32MZ.32MZ2048EFH064
Generated by: Flowcode v10.0.4.33
Date: Saturday, August 26, 2023 10:55:38
Users: 1
Registriert für: SpeedPic32 (24146314)
Lizenzschlüssel:H7PVJQ
https://www.flowcode.co.uk
Using <PICkit4 IPE External Power> inbuilt settings for compiler
Start des Compilers...
C:\Program Files (x86)\Flowcode\Compilers\pic32\bin\xc32-gcc.exe -mprocessor=32MZ2048EFH064 -O1 -o "C:\Users\uwe\Documents\Daten\Flowcode_Projekte\USB CDC.elf" "C:\Users\uwe\Documents\Daten\Flowcode_Projekte\USB CDC.c"
C:\Users\uwe\Documents\Daten\Flowcode_Projekte\USB CDC.c:460:23: fatal error: CDC_Setup.h: No such file or directory
// .Return = 0
compilation terminated.
C:\Program Files (x86)\Flowcode\Compilers\pic32\bin\xc32-gcc.exe Hat den Fehlercode 0xFF gemeldet
Autoclose turned off
BEENDET
PIC32MZ2048EFH064 / 100 USB CDC
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: PIC32MZ2048EFH064 / 100 USB CDC
In your previous post, you made the following comment:
Can you please explain what the solution was? I think the same solution should fix the issue you are having with v10.Hello I have it
in the compiler options was for whatever reason a wrong entry set as default, sorry
SpeedPIC32
hello Steve-Matrix
i tried to set up my software in FC9 and FC10 according to these instructions.
Right here is what you currently need to do to solve the compilation problem.
1) You need to download and install the Harmony 1.11 library from here. This contains the USB drivers and missing files.
https://www.microchip.com/mymicrochip/f ... e=en597939
Make sure you install the harmony library in the default location C:\microchip\harmony\v1_11
2) In Flowcode click Build -> Compiler options
3) Select the PIC32 programmer you are using ICD3/PICkit3/PICkit4 from the list on the left and then click on the save button at the top right of the window.
4) Give the setting a new name e.g. PIC32 USBSerial
5) Select the new item you have created in the list on the left and change the compiler location to one of the following.
HID
$(compilerpic32)batch\PIC32compHID.bat
Serial
$(compilerpic32)batch\PIC32compCDC.bat
6) Change the compiler parameters to this.
"$(chip)" "$(srcdir)" "$(target)" "$(family)"
7) Tick the "Default compiler for platform" checkbox
8) Click the OK button
9) Next extract and copy the updated compiler scripts to the toolchain folder. C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch
i have the PIC Kit 4 Programmer.
FC10 I have even reinstalled. I can't get it to work.
I just tested a PIC32MX. 3 guesses. It compiles into FC10 with no errors. As soon as I take an MZ chip, it doesn't work any more. FC9 still does it differently. Compiling works with MX as long as I have USB_Serial in Explora but do not use it in Main. As soon as I only call Init. the compilation aborts.
Translated with www.DeepL.com/Translator (free version)
FC10 error
Title:
Description:
Device: PIC32.32MZ.32MZ2048EFH100
Date: Tuesday, August 29, 2023 14:07:17
Users: 1
Using <CDC1> user settings for compiler
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat "32MZ2048EFH100" "C:\Users\uwe\Documents\Daten\Flowcode_Projekte\" "USB CDC" "32MZ"
Project USB CDC
Device 32MZ2048EFH100
Objects USB CDC_32MZ2048EFH100
C:\Users\uwe\Documents\Daten\Flowcode_Projekte>xc32-gcc -mprocessor=32MZ2048EFH100 -DMX_USBHS -IC:\Users\uwe\Documents\Daten\Flowcode_Projekte\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "USB CDC_32MZ2048EFH100\USB CDC.o" "USB CDC.c" -DMX_USBHS
USB CDC.c: In function '_IntHandlerUSBInstance0':
USB CDC.c:350:27: error: 'sysObj' undeclared (first use in this function)
DRV_USBHS_Tasks_ISR_USBDMA(sysObj.drvUSBObject);
USB CDC.c:350:27: note: each undeclared identifier is reported only once for each function it appears in
USB CDC.c: In function '_IntHandlerUSBInstance0_USBDMA':
USB CDC.c:354:34: error: 'sysObj' undeclared (first use in this function)
#ifdef MX_PIC32_MX
Error(s) in build
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat Hat den Fehlercode 0x1 gemeldet
BEENDET
HID
Serial
FC10 error
Title:
Description:
Users: 1
Project USB CDC
#ifdef MX_PIC32_MX
Error(s) in build
BEENDET
- Has thanked: 795 times
- Been thanked: 858 times
Hello the PIC32compCDC.bat that required replacing has these lines:
Therefore you will need to make sure you change the path for v10:
Also, it's Harmony v1.11 that's installed.
Edit:
I have just installed Harmony v1.11 and compiled your attached project.
Here are the results with the first few lines removed:
@SET MX_CAL_USB=C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC
@SET MX_HARMONY=C:\microchip\harmony\v1_11Code: Select all
@SET MX_CAL_USB=C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDCEdit:
Using <USB32> user settings for compiler
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat "32MZ2048EFH064" "D:\FlowcodeTesting\" "USB CDC" "32MZ"
Project USB CDC
Device 32MZ2048EFH064
Objects USB CDC_32MZ2048EFH064
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "USB CDC_32MZ2048EFH064\USB CDC.o" "USB CDC.c" -DMX_USBHS
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device.c" -o "USB CDC_32MZ2048EFH064\usb_device.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device_cdc.c" -o "USB CDC_32MZ2048EFH064\usb_device_cdc.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device_cdc_acm.c" -o "USB CDC_32MZ2048EFH064\usb_device_cdc_acm.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\int\src\sys_int_pic32.c" -o "USB CDC_32MZ2048EFH064\sys_int_pic32.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\devcon\src\sys_devcon.c" -o "USB CDC_32MZ2048EFH064\sys_devcon.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC\CDCComp.c" -o "USB CDC_32MZ2048EFH064\CDCComp.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC\CDC_HS_Desc.c" -o "USB CDC_32MZ2048EFH064\CDC_Desc.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC\SYS_TMR_PROXY.c" -o "USB CDC_32MZ2048EFH064\SYS_TMR_PROXY.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\driver\usb\usbhs\src\dynamic\drv_usbhs.c" -o "USB CDC_32MZ2048EFH064\drv_usbxs.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\driver\usb\usbhs\src\dynamic\drv_usbhs_device.c" -o "USB CDC_32MZ2048EFH064\drv_usbxs_device.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -DMX_USBHS -ID:\FlowcodeTesting\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\devcon\src\sys_devcon_pic32mz.c" -o "USB CDC_32MZ2048EFH064\sys_devcon_pic32mxz.o"
D:\FlowcodeTesting>xc32-gcc -mprocessor=32MZ2048EFH064 -c -I"C:\microchip\harmony\v1_11\framework\system\devcon\src" "C:\microchip\harmony\v1_11\framework\system\devcon\src\sys_devcon_cache_pic32mz.S" -o "USB CDC_32MZ2048EFH064\sys_devcon_cache_pic32mz.o"
D:\FlowcodeTesting\USB CDC_32MZ2048EFH064>xc32-gcc -mprocessor=32MZ2048EFH064 -Wl,-T"C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\..\bin\..\pic32mx\lib\proc\32MZ2048EFH064\p32MZ2048EFH064.ld",--defsym=__MPLAB_BUILD=1,--defsym=_min_heap_size=0,--gc-sections "CDCComp.o" "CDC_Desc.o" "drv_usbxs.o" "drv_usbxs_device.o" "sys_devcon.o" "sys_devcon_cache_pic32mz.o" "sys_devcon_pic32mxz.o" "sys_int_pic32.o" "SYS_TMR_PROXY.o" "USB CDC.o" "usb_device.o" "usb_device_cdc.o" "usb_device_cdc_acm.o" -o "..\USB CDC.elf"
D:\FlowcodeTesting\USB CDC_32MZ2048EFH064>xc32-bin2hex "..\USB CDC.elf"
D:\FlowcodeTesting\USB CDC_32MZ2048EFH064>xc32-objdump -t -d -h "..\USB CDC.elf" 1>"USB CDC.lst"
D:\FlowcodeTesting\USB CDC_32MZ2048EFH064>xc32-size -B "..\USB CDC.elf"
text rodata data bss dec hex filename
24948 584 780 848 27160 6a18 ..\USB CDC.elf
Compilation successful
Using <USB32> user settings for linker
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\bin\xc32-bin2hex.exe "D:\FlowcodeTesting\USB CDC.elf"
FINISHED
SpeedPIC32
Hello medelec35
I have changed the batch file from
that made
@SET MX_CAL_USB=C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC.
with this change FC10 runs when I compile PIC32 chips.
Thanks for the tip
that made
Thanks for the tip
Hi SpeedPIC32.
Thanks for letting us know FC10 runs when you compile PIC32 Chips.
This thread will be handy for anyone migrating from FC9 to FC10 with PIC32 target devices that use USB.
