I hate messing with things that "work" especially if relying on other software, so my plan was pretty much as you suggest. Uninstall, registry clean and then a fresh install using 5.1. Unfortunately I had to leave shortly after I sent the update so I'll do it next time I'm in front of it.
I appreciate v5.x is work in progress so my posts are more FYI as I have another machine with 4.x that pretty much works most of the time.
ESP32 IDF v5.0 Support
- Has thanked: 360 times
- Been thanked: 575 times
Re: ESP32 IDF v5.0 Support
Uninstalled, ran a Registry cleaner, rebooted then did a fresh install using v5.1.1.
Happy to inform that the speed of the UART can now be changed from 115200.
Thanks.
Thanks.
