ESP32 problem with components
Has thanked: 246 times
Been thanked: 258 times
There is a another small cheap ESP32 module for less than 10 euros. It can be easily programmed with FC9.
I put an external led on pin G33 and it's flashing nice. But if I init the LEDWS2811 its not compiling anymore.
Also some another components make problems on another ESP32 Modul.
Is this just on my computer?
Some info about the modul:
https://www.digikey.bg/product-detail/e ... D/12088569
Has thanked: 647 times
Been thanked: 856 times
Re: ESP32 problem with components
Hi Stefan,
Not not just you there are some known issues with some components currently on ESP32 we are looking into, including WS2811, Servo Motor, 1Wire. We hope to have a solution for these issues soon.
The WS2811 component should now be fully functional with the ESP32 hardware. Hopefully others will follow shortly.
After the update today it's Perfect!
Every thing is working nice with WS2812 LED. Also in the simulation.
Unfortunately that doesn't work anymore. I can no longer compile to target with the WS2812 included. With the library updates I have also tried old versions of the component, but no success.
Without the WS2812 there is no problem compile to target.
Hi Stefan,
Looking for you now, can you see what compile error messages you are getting. Or please can you attach your .msg.txt file so we can try and pinpoint what's going wrong for you. Strange that earlier versions of the component are not solving the issue.
I put the errors in a file.
I just tried version 8,9,10,11
FC9_M5STACK Modul Atom Matrix_empty.msg.txt
(18.79 KiB) Downloaded 859 times
Error.txt
(18.77 KiB) Downloaded 837 times
In the last post was the component V8
Here is the .msg.txt compiled with component V11
(18.36 KiB) Downloaded 919 times
Hi Stefan,
Have you done a full database update it looks like maybe the rmt component is maybe not fully up to date.
I'll do some tests here and double check everything is OK at this end.
If you mean the component library, yes I prefer always to do all the updates from the complet library.
Or do I have to reset the component library?
