The dsPIC33CH dual-core DSCs are developed recently. Basically, its two dsPIC33C devices on a single chip. <
Is support of this device will be available with further Flowcode versions?
For more information about controller:
https://www.microchip.com/en-us/product ... l-core-dsc
Suggestions for new microcontroller support
egearabaci
- Has thanked: 3 times
- Been thanked: 2 times
Re: Suggestions for new microcontroller support
Although they are 8051 based could the Nuvoton range be considered as stock seems to be available and they are cheap. see link below
MS51FB9AE Nuvoton Technology Corporatio ... | DigiKey
Sanjay_Singh
- Has thanked: 1 time
- Been thanked: 1 time
I need Device support for PIC16F152xx family.
San
San
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
my suggestion is a PIC18F27/47/57Q84
It is super equipped
https://ww1.microchip.com/downloads/aem ... 02213D.pdf
If possible record as soon as possible
with kind regards
SpeedPic32
with kind regards
SpeedPic32
pmgreene01
- Has thanked: 4 times
- Been thanked: 5 times
I am interested in working with the Arduino Nano ESP32 board. Since you support ESP32 and Arduino, I was wondering if this new board could be supported without a lot of effort.
https://docs.arduino.cc/resources/datas ... asheet.pdf
Although RPi availability is getting back on track, the yr+ hiatus accelerated interest in Radxa's RockPi chipset and various board platforms as a solid RPi contender.
You can also generally use the RPi compute module platform to connect Radxa boards, although the Radxa compute module further offers more IO through a third CM interface connector.
Perhaps something to consider?
All the best,
Brendan
All the best,
Brendan
- Has thanked: 272 times
- Been thanked: 443 times
Hi Bob,
That's a timely question as we will be releasing a major update to Flowcode v10 soon which has a brand new feature to allow Flowcode App Developer projects to produce code that will run in a browser. These will work on a wide range of devices (anything with a decent browser) and will include most Android devices.
More details should follow, later this month or next.
- Has thanked: 432 times
- Been thanked: 647 times
That sounds a very interesting prospect. Looking forward to learning more.
I though you guys had been a bit quiet recentlywe will be releasing a major update to Flowcode v10 soon which has a brand new feature to allow Flowcode App Developer projects to produce code that will run in a browser.
