RPi File Component
rotaxmax55
Flowcode v10 RPi File Component
Post by rotaxmax55 »
I cannot get the RPi File Component to build.
I have updated component to latest versions.
Created the simplest of projects to test after I experienced difficulties but even this will not build, I get the following errors:
Building RPi_NVS_Test_190923
RPi_NVS_Test_190923.c:223:29: error: missing terminating " character
FCI_SHEAD("$(srcdir)",10, "\",1, FCL_FILEPATH,200);
RPi_NVS_Test_190923.c:225:3: error: expected expression before 'switch'
switch (FCV_04651_File_RPI1__FILE_IDX)
from RPi_NVS_Test_190923.c:36:
RPi_NVS_Test_190923.c:331:1: error: expected ';' before '}' token
RPi_NVS_Test_190923.c:974:29: error: missing terminating " character
RPi_NVS_Test_190923.c:976:3: error: expected expression before 'switch'
RPi_NVS_Test_190923.c:1084:1: error: expected ';' before '}' token
Error(s) in build!
Any help please.
RPi_NVS_Test_190923.fcfx
(7.46 KiB) Downloaded 963 times
Has thanked: 800 times
Been thanked: 865 times
Re: RPi File Component
Until the cause is investigated, can you try rolling back to revision 1?
To rollback you can follow the instructions here.
Roolback Component.png (27.54 KiB) Viewed 13069 times
rotaxmax55
OK, thanks, rolling back to revision 1 allows compile to succeed.
rotaxmax55
Moving forwards with the project now that I can compile I have created a simple test of the file function:
1. Create a file
2. Open the file
3. Append bytes to the file
4. Close the file
This compiles and transfers to the RPi and appears to run, Putty session opens then closes.
I can see the project on RPi but I can't find the file that it should have created having searched the whole RPi filesystem.
Of course now I don't know if the RPi file component is too out of date to work.
RPi_NVS_Test_200923.fcfx
(8.56 KiB) Downloaded 1019 times
Has thanked: 649 times
Been thanked: 856 times
Hopefully solved for you now, I've fixed the component and also pushed a fix to the RPI File CAL code.
Please let us know if this makes any improvement for you.
rotaxmax55
Something's gone wrong. I can't build but with a different error:
C:\Users\david\OneDrive\CE Jobs\Agri\Autotrap 2023>REM DIR: FCD\RPI\batch\rbuild.bat
Building RPi_NVS_Test_200923
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:407:0,
from RPi_NVS_Test_200923.c:102:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\RPI\RPI_CAL_File.c:45:25: fatal error: esp_vfs_fat.h: No such file or directory
#include "esp_vfs_fat.h"
compilation terminated.
Error(s) in build!
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\RPI\batch\rbuild.bat reported error code 0x1
And when I try to update the components I get a 'not genuine' version shown for, I think, the same component:
I am unable to download and update this component.
Many apologies, should be resolved for you now.
