UART Baud Rate Arduino Mega 2560 R3
bierbaum
Has thanked: 2 times
Been thanked: 1 time
Post by bierbaum »
I have implemented serial communication between two devices via the UART (RS232) component. If I switch from Channel 1 to another channel I have to double the baudrate in the properties to get the right value (eg. 230400 in the properties means 115200 in real life). Am I doing sth. wrong? Just switched from FC6-FC7-FC8-FC9 (Prof. Version).
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Re: UART Baud Rate Arduino Mega 2560 R3
Post by SpeedPIC32 »
the PIC32 have the same problem
There it is four times
Greetings SpeedPic32
LeighM
Has thanked: 96 times
Been thanked: 291 times
Post by LeighM »
I will look into it asap
Has thanked: 156 times
Been thanked: 902 times
Post by mnfisher »
LeighM
Post by LeighM »
Bug found and fixed.
Hopefully in the update system soon.
bierbaum
Post by bierbaum »
Works much better now. Thank you very much for the quick response!
