Installing and setting up of ESP32 toolchain
artan
rtc
Post by artan »
does anyone have an example with pcf6853
jay_dee
Has thanked: 102 times
Been thanked: 74 times
Re: Installing and setting up of ESP32 toolchain
Post by jay_dee »
With heavy sigh I agreed to try an get the ESP toolchain on another machine.
I understand the ESP Toolchain Wiki has been updated and so I went step by step on the new desktop. Everything was as per the Wiki showed.
When setting the FC Global settings > Locations > ESP
what file/directory should this be looking for? There is no C:esp-idf as shown in the Wiki.
During set up the directory C:\esp-idf-tools was specified, this has been popoluated with all the usual files but in zipped format.
It like there is a step missing where the esp-idf unpacks and installs in the C:\ direcory?
What is the usual method of initiating this?
It looks like the ESP toolchain is still a tricky little git, ha! :)
Thanks guys. J.
Has thanked: 795 times
Been thanked: 858 times
It looks like you missed a step.
The 5th image down in the Wiki Compiler toolchain ESP32
That is also the same path entered in Global Settings > Locations Tab
Edit: For anyone reading this, we now recommend to instal idf 5.1 as idf 4.3 causes compiling issues.
jay_dee
Post by jay_dee »
Thanks Martin.
Sorry that was my cockup.
uninstalled, rebooted machine and followed the guide again. All worked as you showed in the install guide.
I have a flash program running on an ESP32.
Many thanks.
regards, John.
Hi John, You're welcome
it's easy done.
jay_dee wrote: ↑
Wed Nov 08, 2023 10:23 am
That's brilliant!
Thanks for letting us know.
