Arduino Uart Parity
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Arduino Uart Parity
Post by Alan_37 »
I need to to use the UART with even parity enabled on an Atmega328p
anyone know what C code I need to add please ?
Found the following on the web but don't know how to implement for flowcode
seems that register UCSR0C is responsible for parity but don't know how to .
void serial_init ( unsigned short ubrr ) {
UBRR0 = ubrr ; // Set baud rate
UCSR0B |= (1 << TXEN0 ); // Turn on transmitter
UCSR0B |= (1 << RXEN0 ); // Turn on receiver
UCSR0C = (3 << UCSZ00 ); // Set for async . operation , no parity ,
// one stop bit , 8 data bits
Has thanked: 177 times
Been thanked: 1016 times
Re: Arduino Uart Parity
Post by mnfisher »
From the datasheet:
So you need to set bits 4 and 5 correctly,
UCSR0C |= 1 << UPM01; // Set UPM01 to 1
UCSR0C &= ~(1 << UPM00); // Clear UPM00
Alan_37
Post by Alan_37 »
Hi Martin ,
Thanks for your fast reply , so I put the 2 lines in a c code
and put it after INIT uart is that right ?
I try it and let you know
Thanks again
Post by mnfisher »
Maybe - you'll probably need to check the UPE flag in UCSR0A to check for errors? If it works :-)
Alan_37
Post by Alan_37 »
Hello Again ,
It works perfectly !! :)
Thanks so much for your help
Post by mnfisher »
That's great - thanks for the fast feedback too....
