STM32f401 Not Working
LeighM
Has thanked: 110 times
Been thanked: 302 times
Re: STM32f401 Not Working
Post by LeighM »
Yes, the live data is in a Windows hidden directory
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\
V9 not V10 in your case
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Post by Alan_37 »
Hi I also managed to find that file by doing a search and edit it
also changed the ram value as it was 98K
But still in flowcode dose not change .
flash .jpg (21.72 KiB) Viewed 8735 times
I think you will need to do it via an Library update
LeighM
Post by LeighM »
I don't think that list comes from the fcd.
It will be worth trying your modified version anyway.
Just also ensure that <root> is the very first thing in the fcdx file.
No doubt someone at Matrix will update the system soon
Alan_37
Post by Alan_37 »
I have tried it and still don't work
Also the hex offset is still bigger then the the chip memory
LeighM
Post by LeighM »
OK, there might be other things to change too, I will know better once I get to my PC :)
Unless Matrix get there first :)
Alan_37
Post by Alan_37 »
I think is fear to ask how matrix can sell a product and not even test for
at least a basic function like blink an led .
Thanks for your help LeighM, looking forward to make this work :)
LeighM
Post by LeighM »
It's a tricky balance between testing every device, and thereby having a reduced set, or creating untested fcds for the gaps with the risk of a bug.
Alan_37
Post by Alan_37 »
I understand hope it will be fixed soon
LeighM
Post by LeighM »
I've now had chance to have a look...
The fcdx looks correct (where it matters) ...
    <parameters>
        <lscript value = 'stm32f.ld' />
        <romsize value = '256K' />
        <ramsize value = '64K' />
    </parameters>
The project clock setup has issues, please could you try the following changes to your settings (this will limit all the clocks to maximums)
RCC_PLLM /25
RCC_PLLN x336
RCC_PLLP /4
RCC_PLLQ /4
RCC_AHB_PRE /1
RCC_AHB1_PRE /2
RCC_AHB2_PRE /1
Alan_37
Post by Alan_37 »
Hi , is the memory part i was talking about in the section below that
it is not correct , should be flash bytes = 262144 & ram = 65536 .
    <memory >
        <flash bytes='524288' />
        <ram bytes='98304' />
    </memory>
Yes it finally worked with your clock settings also had to select HSE would not work on EXT,
so it was the clock settings.
I would never get it to work without your help
Thanks so much
